This will enable much more flexibility in FX as well as transitioning between songs.
Thanks for the suggestion! I’ll share this with our devs for consideration.
This could be done using the same logic like frequency change knobs swith to stems. Just on the filter knob. Or, even better, this could be mappable on the other knobs, when you want to use it on Xone K2-K3 etc. ![]()
Thanks for the input @Akrilovy
