Greetings,
I installed Big Sur Beta on my MacBook Pro and the sound coming from the default output speaker sounds distorted. With all other software, the sound is clear. I didn’t yet try to run it with my DJ controller yet but suspect it will also be that way.
Does anyone have a solution on clearing up the sound?
Maybe there’s an updated driver for Big Sur?
Thanks.
