Device model * IPad Pro 11 inch 4th generation
Version of operating system : 17.6.1
Version of djay 5.2.4
Hardware/controllers used DDJ rev 5
Summary of the issue:
When Dj’n the past few nights at live gigs I notice a very annoying distortion when transitioning to the next song. I don’t have or have been using crossfader effects and it is not on. The distortion is to the point where I can’t use DJay at a life event.
How to reproduce the issue:
It happens almost every other song. Just transitioning to the next song…… I’m either scratching or blending. The distortion last a good 5 to 7 seconds.
I mostly use tidal and also music stored locally on my iPad. I use playlist i created within djay.
Hi @Five-0, thanks for the details about your setup and the issue. To help me accurately communicate this to engineering so they can try to reproduce it, can you please capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here?
Can you please also share screenshots of your djay Settings>Sound?
I think this is my problem. I might have songs volumes turned up…… I may have never noticed it before but the rev 5 sound card is much hotter than any thing else that i use. I’ll leave it off for my gig tonight and confirm if that’s the issue
Thanks for the follow up @Five-0. To help me accurately communicate this to engineering so they can try to reproduce it, can you please capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here?
