When i browse my spotify playlists while a track is playing the playback randomly stutters.
Nexus 7 with Android 5.02 and 5.1 (just upgraded).
Thanks for any solution.
That shouldn’t happen! We’ll look into this.
Does that happen every time you browse Spotify? Does it also happen when browsing through your iTunes library?
Thank you so much for your help!
I tried to reproduce it several times but it only happened again one time. I’m not sure which circumstances led to this behaviour. And yes, it also happened while browsing the local files library.
I will report back when it happens again and i’m able to reproduce it.
The described issue occured for both audio devices. In general you can use usb sound devices (like a dj controller) and also the built in audio out.
I’m not sure if this answers your question.
cheers, rokr
Hello rokr,
can you use the audio output via the usb port with your nexus7 or does it only work over the headphones output? would be great if you could share your experience. thanks in advance!
