I have the Soundbrenner Core https://www.soundbrenner.com/core with its app https://www.soundbrenner.com/themetronome/ . It has Ableton Link. I would like the Soundbrenner to reflect the tempo of the track in Djay Pro.
Now the tempo is only reflected the other way, i.e. the Soundbrenner is the master and Djay Pro reflects the tempo set in Soundbrenner.
How can this be changed so that Djay Pro becomes the master?
Kind regards,
Jonas
Thanks so very much for your reply!! I am forwarding to the Soundbrenner support.
Kind regards,
Jonas
Hi again,
I have been exploring Soundbrenner with Djay Pro a bit more now. I get Soundbrenner to reflect Djay, but not until I have double clicked the Synched track’s tempo so it resets to its original tempo. It is a bit annoying to first click the Synch button and then the track picks up and reflects the tempo of the Soundbrenner; and secondly double click the track’s tempo so it resets to the original tempo and then Soundbrenner picks up that tempo.
The ideal would be to configure Djay Pro so that it is always the master, and that Soundbrenner picks up/reflects the tempo of the track in Djay Pro. Now it is not really smooth and doable, when one has to reset the tempo first.
What are your thoughts? Have I explained the issue clearly enough?
Kind regards,
Jonas
Hi Jonas, Is it possible to receive a Master Tempo by the Soundbrenner device before sending it to djay?
djay will be the Master when there is a track running (active deck). You can also find details information in our FAQ:
https://help.algoriddim.com/hc/en-us/…
