Soundflower not working in demo
Hi
I am trying to record a mix using Soundflower, Audacity and djay Pro 2, for now with the demo. When I set output to Soundcloud Audacity doesn’t pick it up. This approach works with other software, is this feature silently disabled in the demo? I don’t want to buy the full version unless this works as I will be unable to record mixes. I am using MP3s I own.
thank you for your mail. If you want to record your mix in djay Pro we recommend using the internal recording feature of djay Pro which you can access via the red record button.
