Speed up and improve track synchronization
firstly, you can hear how the track is synchronized (this does not happen instantly)
secondly, when using the beatjump function, the tracks shift and it takes a lot of time to synchronize, sometimes the synchronization is lost by a whole beat
, thirdly, the duplication of the soundboard is also not instantaneous
. In tracks where there are moments with different speeds, there is also a desynchronization and you can hear how the track is synchronized back
mackbook m1
djay 5.2.1
any air conditioning
the problem was with them in previous versions
the translator is certainly not accurate)
Hi @mira99g2, can you please try to capture a video of the issues, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
can I send a video to your instagram?
@mira99g2 please do not send to Instagram. Please use the method above or send to me in a DM. Thanks!
this video shows that the tracks diverge, that synchronization takes time
, I couldn’t record it, but at startup, too, and when duplicating
ops
Dropbox
Hi @mira99g2, thanks for the video. This is very helpful.
  1. What is the source of the music you are using (TIDAL, SoundCloud, Beatport, Local Music, etc.)?
  2. If local music, what file format (mp3, wav, flax, etc.) and where are the files stored (device internal drive, external USB, external SSD, etc.)?
  3. Are you running any other applications in the background when using djay?
music from the finder .
mp3 internal drive of the device
other applications are disabled
Thanks for the additional details @mira99g2. I’ve shared this all with our dev team.
