While the semicolon character is technically a nonstandard separator, it’s used a lot as a workaround (esp in the iTunes/Music desktop app, which cannot handle multi-valued tags), and it would be very useful if djay would split Genre tags on semicolons.
Current behaviour: djay creates a new genre “House;Techno”, which causes issues when filtering for genre.
Desired behaviour: djay would split the genres (“House” and “Techno”), like it already does with normal multi-valued genre tags.
I don’t know what database is being used by Djay, but a semi colon is a disallowed character in SQL as it signifies the termination of a query, and will result in an error.
I don’t know what Djay does specifically, im just providing some info on that character in relation to databases. it might provide an insight as to why it’s not commonly used in this kind of application.
I need this too, but for me the separator is a space character (" "). My songs are managed in iTunes (Apple Music now) and in the genre field I type things like “house smooth soulful” or “disco funky uplifting smooth” …
I’d love to create a smart playlist where I could f.e. filter on genre and simply type a freeformat string f.e. “smooth” or “smooth uplifting”.
The same request for filtering on genre in the library directly.
This is really missing from DJay pro, especially for “open format” DJ’s that have a huge collection of all kinds of genres, and want to create bespoke smart playlists or filter on certain combinations of genres.
Interestingly enough (at least for me, I was surprised) is the fact that searching in the collection/library does support “contains” for the genre field (it works with OR, not AND). Only for filtering and smart playlists this doesn’t work.
that would be even more powerfull, I’d be happy already with the same search functionality in smart playlists and filtering that is already there in the “Search my collection” functionality though.
I can imagine implementing this, and other valuable Quality-of-Life improvements in the library-management can take some UX work and thinking, but there could also be a relative simple approach: using “command strings” for certain actions, like f.e. "GENRE: “disco” AND “smooth” or “BPM:130” that can be entered in the search box, free-format filter entry, and smart playlists..
