The split option is not working on my iPad. I payed for a splitter cable made for djs and it works beautifully on my iPhone. It must be the app for the iPad. Is there any way I can fix it or is there an update coming out soon to fix this problem for the iPad version.
Hey George,
thank you for your post.
Which Split Output cable are you using?
Cheers,Lukas E.
