Split Performance Pad Modes
Please add the ability to Split Performance Pad Modes so the Top and Bottom rows of the Performance Pads can be different. This would be similar to what is already available on the Rane 4 and Pioneer Rev 5.
  1. Holding one Performance Pad Mode button while pressing a second Performance Pad Mode button splits the Top and Bottom rows in two.
  2. This allows you to use two Performance Pad Modes at the same time instead of switching between them.
  3. For example, Hot Cues 1-4 on the Top Row and Saved Loops 5-8 on the Bottom Row. Other useful examples would be STEMs and Instant FX or Hot Cues and Loop Rolls.
I agree, this would be very easy to implement I am sure as we would only be utilising what’s already there but with cool enhancements.
If you use this frequently and get along well with four performance pads each, you can simply assign them accordingly via the mapping.
For sure, but the whole point is to have the flexibility to adjust the combination on the fly as needed.
Suggesstion for rane performer can we get mapping for combination of the performance pad like CUE and Stem like how Serato has when you push both button at the same time.
Hi @1103, I’ve merged your new topic with this existing one. This suggestion is to add Split Performance Pad modes to djay which would make it accessible for all hardware, not just the Performer. Please cast your vote at the top left of this page so we can gauge user demand for this feature. Thanks!
Even better would be to take the rekordbox approach and allow hot cues OR loops to be saved to the pads. That way you can have all your hot yes and one or two loops all saved and easily accessible.
Will this get implemented. I am getting frustrated even virtual dj has better mapping.
Hi @1103, thanks for the reminder on this suggestion! I will share this with the dev team again for consideration.
This is one of the great features with Virtual DJ and I was just reading about it as it’s also now implemented with the Rev5. It’d be great to have this option in Djay.
Thanks for the feedback @BillPayer
