Split screen doesnt work properly anymore as you can see from the screenshot the app doesnt resize properly.
iPad Pro
iOS 10.3.2
DJay Pro 1.0.8
Hey Rakanlam,
can you tell me which iOS version and djay version you are using?
Cheers,Lukas E.
same problem here - with same specs.
can i hope for an update soon? can’t use djay pro like this
since this version it was always very good
iOS 10.3.3
djay pro 1.0.8
iPad Pro 12,9 (2015)
hello, I have the same problem
I need an update soon because I use it every day for work
iOS 10.3.3
djay pro 1.0.8
