Hi all, just joined this.
I can use Spotify on the iPhone version of djay but it doesn’t show up on my iPad version.
Is it not available or am I missing something.
iPhone XR, had djay as a default app.
iPad 7, just installed djay app from App Store.
Any info much appreciated.
Thanks.
Gary
You can’t use Spotify at all any more with any Dj apps as they stopped it.
If you can still access it will be because of a legacy app that might have not been updated for a while. But you will still at some point loose the ability to use Spotify at all with either app or desktop. Shame as it was good.
