Spotify Folder Playlist
It is possible to incorporate Spotify Folders playlist? I organize my music as folders for easy search.
It would be really great though, it is very annoying having to pass down all the lists when you have much music organized in folders.
AHHHHHH this is so crazy, I REALLY NEED to access my music in folders, for flow and to be organised!!! Please can you FIX FIX FIX FIX FI X please please please
at the folder system can’t be supported.
Sorry for the inconvenience.
Unfortunately, that is exactly the point.
Cheers,Lukas E.
Work around I use is to make playlists in the djay playlist area and drag in playlists Manually
If You dont support folder playlist it is Not Really compatible with spotify
I please You also to support this
One easy First way Would be to Show all Playlists At The Same Level
Thank You
Eugen
Germany
I think the issue is that spofiy api doesn’t anymore contain functions to fetch and read the folders :frowning:
I second this. would make a big difference. Any work arounds?
is it still not possible to be able to see your spotify folders in Jay pro 2?
Lukas, can you assist in logging into spotify from djay pro 2 in mac os? all that pops up is a white box…
same here need that fearture
