Spotify integration improvements - iOS
I’d like to suggest some enhancements to the Spotify integration. I’m using DJAY 5.6.2 on iOS (iPad), so that playlist and folder access works more in line with how it does in the Spotify app.
  1. Support for Pinned playlists, so stay pinned at the top
  2. Folder support. Ability to navigate folders of Spotify playlists
  3. Custom order for folder playlists. Custom order is only available for playlists inside folders on the Spotify app. DJAY has a custom order filter but no folders, so not sure exactly what this does
  4. Offline music support. I can store music in the Spotify app to play offline. It would be great if I could access this music in DJAY when offline. Currently, the integration is not accessible when offline
Thanks for the suggestions @rishi. I’ll share this with our devs for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
The situation is similar with Tidal; it would also be nice if the folder structure could be viewed within Djay. Of course, you could set up these folders and playlists manually in the Djay library. Unfortunately, changes made on one side do not result in corresponding changes on the other. Perhaps an automatic synchronization could be considered… :wink:
+1 to all of these, also please add an option to “Search” for playlist titles on ipad version.
Thanks for the feedback @TheBarbaryGhost
I made a post suggesting specifically that if you would like to upvote
Searching for playlists on Spotify iOS/ iPadOS
Yes, folder structure please!! (I mean, get the folders defined in Spotify and have that in DJay)
Welcome to the community @Bastien_L. Thanks for the input!
