Spotify keeps saying "this song not streamable"
Just got djay 2 on my iPad. I’m trying to use spotify to stream songs and it just keeps saying “song not streamable”. Why won’t the spotify let me use the songs? Its the main reason I got djay 2, and now it won’t work… Did I just waste 10 bucks?
Hi Mickey,
Sorry to hear that. Which songs are affected so I can check and test it?
I just tried loading songs from the same playlist and had no problem. Can you please check if you can load the same song(s) in the Spotify app? Which country are you in?
I’m having the same issue. It says it for every single song I try.
