Spotify login not responding
Works again
I have the same problem
it works … I do not want to experience the middle of the game at the wedding :frowning:
Same issue here - on Mac computer
Same problem right now. How can I fix it??
reCaptcha not working
I am having a problem with Spotify login. The symptoms are the same as mentioned in this thread- I hit the login button and nothing happens at all. Some people are saying recatcha is the problem but not sure how that helps me.
The update solved the problem, thank you Lukas.
I am experiencing problems with logging on to spotify on my Djay Pro 2 app for mac. When i click “log in”, the next screen is just white. Ive turned my computer on and off. I have re-installed the app. I have updated the app. Nothing seems to work. Any solutions?
