djay cannot access the tracks that you add to Spotify yourself. You can only load “real” Spotify songs. As for your local files, I recommend syncing via iTunes to your iPad, then you’ll be able to play them in djay.
Hi I have this problem in Australia.
An example is Taylor Swifts Shake it Off purchased via iTunes and added as a Local File into Spotify. It will play on the Spotify ipad app but Djay 2 app gives the following message.
"Track Not Available
The Spotify track is not available in your country. "
djay for iPad and iPhone supports all songs nowadays sold on the iTunes Store (called “iTunes Plus”). However, older DRM-protected songs are not supported. To play older DRM-protected songs please upgrade your existing songs to iTunes Plus in the iTunes Store.
I am having the same problem except it is with songs from the iTunes Store. Basically, I have a soundtrack (Portal 2) that will have some songs that work and others that say they are DRM-protected or unavailable. I think they are unavailable because if they were DRM-protected it would be the entire soundtrack.
Because all the music from Spotify is encoded in the DRM-protected format so you cannot directly use it on Djay pro. Maybe you can download Spotify music to your computer using a Spotify music downloader and then use Spotify music with Djay pro directly. Or if you have a Premium account, you can also access Spotify music on Djay pro.
I am having a problem where I can see the song in Djay app on my Mac book and play the song but when I move it to make a playlist in Djay it says the track is not available.
