Spotify Quality Setting and file cache
Do Algoriddim apps use the local Spotify settings for audio quality? I use only Extreme Quality audio on Spotify and want to make sure DJay does too.
Also, will the Algoriddim apps use the files in the local Spotify cache or download them all the time? I would like to use the app offline sometimes and use cached files only.
you can set the Spotify Streaming settings to Extreme in djay too.
Therefore, please open the djay settings > Library > Spotify Streaming Quality.
Please note that due to “sandboxing”, a security feature, apps have absolutely no access to each other’s workspace. This means that djay has no access to the songs you download in the Spotify app. These songs are only available for the Spotify app itself. djay currently has no way to support offline playlists but we are aware of this request and we’ll be sure to keep an eye out.
