Spotify songs don't always load properly
Playing spotify songs on djay pro lastest version on a mac mini 2 with a beatpad 2 (first edition), I ran into multiple loading problems yesterday. 3 different problems probably cause by the same issue :
* full waveform would not load totally
* moving waveform would be cut middle song and either continue playing or stop
* moving wave form as well as full waveform would only load when approching the end of the waveform, then would load 5 more sec (repeat)
I already tried re-installing the application and rebooting the ipad it didn’t solve the problem. It feels more like a bug caused by change in the way the songs are loaded from spotify. My internet connexion is fiber and is rock solid.
Could you please look into it ?
Regards, love your software
