I’m having the same problem.
iPhone 16 max pro. Tried all the steps as well.
Just a heads up. Spotify integration is down on rekordbox and serato, as well. Seems like an issue with Spotify servers. Hopefully it gets escalated and resolved quickly.
Welcome to the Community @DeejayKoyote @Andrew_Young1 @Francisco_Garcia and @Pizslyr.
Hello everyone, can you please confirm if you are still experiencing issues with Spotify this morning? Thanks!
Still an issue…
CT / USA “No Songs”
Still an issue after following the steps given yesterday: log out, reboot, login only within DJay.
Just a workaround, I used https://www.tunemymusic.com/ to transfer my Spotify gig playlists for tonight to Apple Music playlists, just in case. Worked like a charm.
Thanks for confirming @dfrench73 and @jakehelix
@Slak_Jaw I see a new iOS Spotify App update was released yesterday, version 9.1.46. I updated it, and unfortunately still no songs. What’s odd is that you can see all your music libraries in DJ Pro, but no songs in those libraries. One would think you would get both the libraries and songs, or no libraries and no songs. Definitely not a fun issue for you and your team to figure out.
Good luck.
Thanks for the updates @DjRyDad14. I noticed the new Spotify iOS app yesterday as well. We have received reports that this issue also affects other DJ software applications.
This is still an issue this morning. Nothing has changed and Spotify playlists show but songs will no longer display in DJayPro.
Thanks for the update @sykeadelec
At this moment, I can confirm that the same issue is going on Serato and Rekordbox as well.
Thanks for sharing @itsRichySmart. This is very helpful information.
Definitely happening across multiple DJ software platforms:
I am still having this issue.
Hi @MBlask, welcome to the Community! Thanks for the update.
Hi, Im having this issue as well. I’ve tried everything, including a full reinstall and its still is just showing “no songs”. I even tried it on the mobile app to see if it was my PC and it has the same “no songs” error on desktop and mobile. I’m glad to hear its not just me as I thought it was maybe something with my Spotify account. Will keep my eyes out for a fix and thanks to the Algoriddim team for looking into it!
Spotify’s response is “we are a streaming service not an API service” and said the new mix beta feature is what they want everyone to use. I other words, it’s not coming back. Not a bug, this is designed to keep you from using apps like this
Hi @decisive, welcome to the Community! Thanks for the info.
Hello again everyone. I just wanted to follow up and assure you that this issue is being investigated and we’ll share any official updates as soon as we have them. Thanks!
