SSD & USB Hub problem
YOUR QUESTION:
When i conncet external ssd i cant see him on ipad…ddj flx and charging are good…without hub i can see ssd…its pd hub and 45w charger?
Whats problem ?
Hi @Djchris1, this sounds like a connection issue with your USB Hub. Try connecting the hub to power with your original iPad charger and cable. If that doesn’t work, try connecting the SSD to a different USB socket on the hub.
Can flx10 and charging works but ssd no…maybe 45w is problem?
Could be. Maybe try a 100W PD hub.
Its belkin 4 usb port with 100w pd
Do you have a 100W charger to test it with then?
I will buy 100w charger
In the meantime, do you have a regular USB flash drive that you could test with the existing hub and charger?
Might be good to confirm before buying a new charger.
I will check tonight :slight_smile:
Sounds good. Please report back.
It was charger problem …i was buy anker 737 120w and all works good
Excellent! Glad that worked. Thanks for the follow up @Djchris1
