SSL handshake failed
Your question:
“The certificare is not yet valid”
I’m an old Win user, that swithed to iPad.
But years ago the spotify support dropped I had problems. I hade to use apple music.
But now, finnally, Spotify could be used. But not with iPad. It’s a pitty.
So I switched back to my PC/Win. When starting Djay, it said free upgrade to v5.0. But I got this error: “SSL Handshake…”
I installed 5.0 anyway, but then trying to connect to spotify I get this SSL handshake error again…’
What to do?
Hi @ThomasLydhig, welcome to the Community! Sorry to hear you’re experiencing this issue. SSL Handshake / Certifical Not Yet Valid errors typically mean you PC’s date and time are incorrect. Please try the following:
  1. Set Date & Time to Auto
  2. Press Windows + I to open Settings
  3. Go to: Time & LanguageDate & Time
  4. Toggle ON:
    a. Set time automatically
    b. Set time zone automatically
  5. Click Sync now (under “Additional settings” if visible)
  6. Reboot your PC and launch djay
Thanks VERY much! Solved my problem!
Perfect! You’re welcome @ThomasLydhig
