Im new to DJay Pro and I’m not able to get the start and end point to be recognized from iTunes? no mater if i have Use start and end point if available, in auto mix it always starts from the beginning of the song? Is there something I’m missing? using latest version of iTunes, and Djay Pro.
Hi Sam King,
thank you very much for cotnacting us!
You also can set a start and a stop point directly in djay Pro.
When you have set these points the automix recognizes them and automatically starts and ends at these points.
Best regards,
Alex
yes but the transition for the end point doesn’t happen until a short time after the (end point) cue that you set… why is this? I would think that the transition should start exactly where you place the end point.
