If there are records currently on both turntables and I decide to use automix and start fresh with a playlist I select, it will start playing the records that are currently on the both turntables. After the records finish playing it then starts the automix playist.
I want it to start with the playlist I select instead of the current records on there. Is there anyway to take records off before I start AUTOMIX without restarting the app?
