I was wondering if it’s possible to reassign some of the pads functions like in Serato. In Serato you can reassign your sampler pads to work as stem effect pads which will kill vocal, drum, etc but also have the lower pads function as stem effects like vocal and echo out, drum echo out etc. This way you can trigger them on the fly thru the pads instead of going thru the effects and try to replicate it to a kind of mimic this process. Thanks
Hi @Manriquezjose, currently in djay you cannot simply swap entire Pad Modes. You have to remap every button individually for each pad mode. I explain this in more detail in another topic:
