Stems mapping for Numark Platinum FX
Numark Platinum FX
OS- Sonoma 14.6.1
djay - 5.2.5
Love the controller, it mapped pretty much out of the box, but I’d like to use the EQ knobs for stems when shift is either toggled or held.
Does anyone know how to achieve this?
Whilst I don’t have the Numark Platinum FX,
I have mapped my Prime Go to do this as well.
Having a look at an image of the Platinum FX, You could go into the Midi Learn setting and map Shift + Headphone Cue to Toggle Neural Mix EQ for each deck,
So Deck 1 Shift + Headphone Cue and then do the same for Deck 2.
And when you want to swap back to regular EQ just press the same buttons.
Great suggestion maurizio, thanks!
I’d really love it just to be the shift button, but this helps a lot.
I’d also like to change the low/ high pass filter FX buttons with any other effect as the filter pretty much does their job already. Any suggestions how this can be achieved would be great!
Thanks again.
On the Prime Go, there are two buttons that l don’t use which l have mapped to Toggle the Eq Neural mix without the need to press Shift,
You could try this with the LP/HP filter buttons without pressing Shift,
You will just have to confirm first if those buttons are midi mappable,
I just got this mixer and remapped the high/low pass to change views of the djay interface. Not sure how much I’d use it but it can switch to the 4 deck view if that’s ever something I’d use considering the deck switching is built into this controller.
