stereo recording + pre-cueing
Hello!
It would be a nice (and not so hard to implement) addition to be able to pre-cue tracks but still recording the main mix in stereo. For this there is 2 options, both are good for me:
  • keep the same actual behavior (split/mono for cue+mix) but before record the main mix in stereo before downmixing it to mono for the output. You just need to split the signal here, this is the best solution for all but it needs some work.
  • allow to use the hardware output for pre-cueing in stereo (no split), while the mix is being recorded in stereo. There is no output for the main mix (except for the recording), and this is useful when you’re not mixing for a stage but for recording only. This is a more simple solution (nearly no work needed since no split / downmix is needed), but it’s not as elegant as the first one.
I would be happy with any of these solutions!
Thanks a lot for your app, I hope you keep updating djay for ipad/iphone even though you have a new app (vjay) on the rails!
I second this, it is a great idea that seriously expands the usability of this app. If I am going to take the time to make a DJ mix I at least want it to be stereo and the mobility of this app and the good interface make it a great choice for mobile mix recording, please implement this feature! Thanks too for all the work to get it to the place it is at too!
Lord is this a problem for me. Co-sign!
Stereo recording would be my top priority for Algoriddim right now! The SQ is horrible when I play my music back. Please Algoriddim fix this!
This issue is exactly the main problem with djay. Please make it record in stereo!
Mono recording sounds so outdated in 2012
Just finished a mix only to listen back and find it is now in mono and sounds terrible. What a weird feature - who would want to record in only mono??? at least give us the option to choose.
