Strange behaviour other Deck when using Censor Effect
The Censor Effect (Instant Effect under Chapter Noise & Sweep) is a very nice one. It reverses the playing direction of a track (secret messages :scream: :grin:) and gives a nice effect that is you can use live.
But… after I played a little with it I stumbled across something that must be a bug:
Having the effect on a track in Deck One does effect a track that is playing under Deck 2 after you hit a HotCue in Deck 2. Now Deck 2 also reverses the playing direction (and I can’t Imagine this is the intention)
And it goes even worse when Deck 2 seemingly can’t reverse to normal anymore (it kept doing that even after reloading a track). Also the direction of the picto in the Play button of Deck 2 reverses.
You see all what happened here in this video I recorded.
Device: MacBook Pro (16", 2019)
Operating system: Apple Os / Sanoma 14.6.1.
Djay version: Djay Pro 5.2.5
Hardware/controllers used: Reloop Mixon Pro 8
(But Demo just on Laptop)
Hi @DJ_Big_Blender, thanks for the details about your setup, the issue and especially the video. This is very helpful and I agree this is certainly unexpected behaviour. I’ve passed this onto our engineering team to see if they can replicate the issue and offer any suggestions. I’ll report back when I have news. Thanks!
Hi again @DJ_Big_Blender, engineering was able to replicate the issue and address it. It should be fixed in an upcoming djay release (likely 5.2.6). Thanks again for sharing.
That’s great news! Thank you so much.
Was it only the Censor effect that was affected, or were other effects also impacted?
You’re welcome. Only the Censor FX.
You also have the Twist function (under Classic), which seems to work exactly the same as the Censor function.
I just noticed that the Twist function had the same issue with reversing the other deck.
Hi @DJ_Big_Blender, thanks for sharing and I have passed this on. However, I believe the source of the issue was more related to the sync function than the specific FX used.
Hi!
Thanks for the clarification and for passing this on.
However, I’m still curious—what is the actual difference between the Twist function and the Censor function? Could you explain? As they seem to behave identically to me.
Hi again @DJ_Big_Blender, both Instant FX had the same underlying issue and the fix addresses both. Twist is essentially Censor + an added delay effect.
Hi @DJ_Big_Blender, djay 5.2.6 has just been released and this should now be fixed. Thanks!
Hi Slak,
Thanks for letting me know. Atm the new 5.2.6. version isn’t in my Appstore yet, but I will try it once it’s available here.
Also from the changelog it looks like this other bug is fixed as well in 5.2.6?!
You’re welcome @DJ_Big_Blender
