Strange Bug Traktor S2 & djayPro
Had a gig last night, but I’ve never seen this bug before. I had my Traktor S2 running in Midi mode to my MacBook Pro running 10.12. Everything was going smooth, until a couple requests came in. When I would search my iTunes library, djay would loose focus on the keyboard and instead of typing in the search field, it would start hitting the hotkeys jacking up whatever song was currently playing. I think it was even typing in the search field and doing the hotkeys at the same time. I’m not sure what happened, but I have never seen this bug before, and the only thing that has changed in my set up was upgrading to MacOS Sierra. Any idea? Suggestions?
Hi Abram Stamper,
thank you for your post. This issue is due to macOS Sierra. We are testing our fix at the moment and will provide an update shortly.
Sorry for the inconvenience.
