I use a virtual cable as an audio device. I use BUTT to stream the music to a shoutcast server via that virtual cable. That works great. However, I am wanting to stream the meta data that contains the artist and title of the song that is playing. BUTT has the option to stream a history text file that is updated as the new song is added to that history that in turn broadcasts that meta data to the shoutcast. I saw the post where the history file is located however, there is no text file there only another type of file that isn’t usable. Is there a text file created (or similar, or can i create one) for the history somewhere? Thank you. I see questions relating to this on the forums but don’t see a response that answers the question, so I am going to ask it again.
Hi @DJJC,
Thanks for the question!
Currently, djay does not store playlist history in a text file format that can be used as you described. This functionality wasn’t built into the app, but we appreciate your suggestion and will share it with our engineering team for consideration.
Have a nice day!
Thank you for your reply and consideration on the subject. I hope it does have the option soon!
