In Djay Pro, I am wanting to stream the videos to my Tv while using my mixer and powered speakers. Basically, I don’t want the sound to come from TV. I am using an iPad, and I have an adapter with a HDMI port and a lightning charger port. I understand that I need an adapter with a 3rd port, but not sure which one. My normal DJ gigs I plug into my iPad with a splitter through the headphone port. ( Splitter has headphones and cable for mixer). Now I want that along with the video stream. Any help???
- I don’t have the same iPad model as you so I’m guessing a bit here, but it sounds like you have an older iPad with Lightning port and a headphone socket.
- The way iOS typically works is it uses the LAST device connected to it for audio.
- So, connect your iPad to your TV with your Lightning to HDMI adapter and also connect your iPad charger to the adapter.
- After confirming you have signal to the TV, connect your splitter cable as usual to your mixer via the iPad headphone socket.
- Now the video should be on the TV and audio to your mixer.
- If for some reason audio switches back to the TV, simply unplug the splitter cable from the iPad headphone socket and plug it in again.
@bgoods62 you should also be aware of the Control Center options available on iPad.
- Swipe down from the Top Right of the iPad screen to open the menu.
- Then select the TV icon.
- In here you should see all of the connected audio options available to you. In my case my USB-C dock which has the HDMI connection and my Beats Bluetooth headphones.
- Simply select the device you want to use for audio output here.
@Slak_Jaw
Thanks for the info. I have a IPad 9th Gen. I will try that tonight after work.
@bgoods62 you’re welcome. Hope that helps.
@bgoods62 I’m curious to hear if that fixed your problem.
It turns out there are 2 different audio settings in the app. I had to have the main output to my headphones/mixer. The other one was for the HDMI port. As soon as I had them both synced up, it worked. Just noticed a slight delay in the sound, voices don’t exactly match up. Seems to be mainly on older videos. But it’s not too far off.
Glad to hear you got it working
