My iTunes library is rather extensive, so it is located on an external Firewire drive.
Every time I load djay it says: “Your iTunes library is located outside the Music folder. Please press ‘OK’ to allow djay to access your library”. It tries to guess that my library is in my Documents folder.
I press OK, and the window just comes back again. I then select the hard drive where the library actually exists, press OK and it still asks me the same question.
Had the same problem, even though my library is on my Mac (and I didn’t do anything save for adding new music) and the message “Your iTunes library is located outside the Music folder. Please press ‘OK’ to allow djay to access your library” just appeared after 2 years of never having a problem.
I followed the steps mentioned above, seems to work fine now, but any idea as to what caused the problem?
This reply was created from a merged topic originally titled Load Song Error.
Whenever I add a song to the turntable, I get the popup “this song is located outside the music folder. Please click “OK” to allow djay to load this song.” Why do I keep getting this error and how do I make it stop? Thanks
So trying to be clear, when i launch DJAY, everything’s run fine… I’ve got all my playlists on the left side.
BUT, when i launch the "AUTOMIX " function, i’ve got this pop-up window coming…
I mean every time… in the same session…
not a big deal, but i need to strike my computer keyboard to validate… each time… while mixing…
this issue occurs on my macbook pro under Mavericks 10.9.4 with Djay 4.2.2
With Snow Leopard on another partition… NO PROblem…
But, i Had to go to Mavericks, to use my Kontrol X1mk2
I’ve been browsing for folders in both Hard drives… “Mavericks” and “Snow Leo” but same result.
I’m a bit scarded to mess up things creating a “new library”
Just updated Djay to 4.2.1. When I open the app now it says my iTunes library is located outside my music folder and asks me to click ok for the right file extension. Every time I click on my iTunes library the same pop up keeps coming up.
Before updating, my iTunes library automatically loaded when i opened the app.
I am having the same problem. DJay is stuck on the window “Please click “OK” to allow djay to access your iTunes library.” I select OK or cancel, nothing happens. I’ve tried the instructions in the “Promoted Response” above, but same outcome. I can’t get past the window to OK access to the library…
I am a begginer with DJay2 (2.7.2 version) for Ipad2. How do I play “my” songs? I do the following:
Enter itunes
Once in itunes, Enter Ipad (cable connected)
Enter “Apps”
Enter Djay2
Add a song from my notebook
I quit itunes, go to Djay2, BUT where is the song supposed to be found?
“My files” looks empty…
