Sudden Auto Shut Down - iPhone 18 Pro Max
  • Device model (e.g. 2020 iPad Air 4th Gen): iPhone 18 Pro Max
  • Version of operating system (e.g. macOS 14.4.1): 27.0.1
  • Version of djay (e.g. 5.1.2): 5.6.9
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): N/A
  • Hardware firmware version (e.g. 1.0.1): N/A
  • I only use my iPhone version in auto mix for the car or need some background music. I have noticed since iOS27 the app is shutting down at random times. There is no rhyme or reason as to when, the number of songs played can be different the only that is constant is that I am connected to an audio source via Bluetooth so I don’t know if this would happen if I was not. When listening via AirPods, there is a piercing short white noise sound before shutting down
  1. Unable to recreated because shut down is random
C) EXPECTED RESULTS:
  • Don’t shut down
D) ACTUAL RESULTS:
  • Shutdown
Hi @Leigh_Brown, to help us troubleshoot your crash, I’ve submitted an Official Support Ticket on your behalf. One of our support team members with contact you shortly via email. As I won’t have access to your crash report, I’ll consider this community topic closed for now and let the official support team take over from here. However, I’ll keep this topic open in case other users experience the same issue. Thanks!
Hi again @Leigh_Brown, in the meantime, you could try changing your Automix transition type to a non-Neural Mix one. I recommend trying something like Filter or EQ instead of Automatic. There have been reports of issues with NM with the iPhone 18 so this could be related.
This should be resolved in the recently released 5.6.10. Thanks!
