Sugar Bytes, Looper FX
  • Device model iPad Pro 3rd gen:
  • Version of operating system (iPadOS 18.6.2):
  • Version of djay 5.4.2:
  • Hardware/controllers used none:
Sound artefacts when Looper FX is ON and takes sample at the song load and the other deck is playing. If the other deck is paused or volume at minimum then de Looper FX sounds just right.
If it’s toggled off/on the artefact goes away but it’s annoying if you wanna have the fist loop sample perfect to be used at buildups.
Keep “Sugar Bytes > Looper” ON and load a song with a loop automatically activated while a song is played on the other deck.
Hi @Gabi0110, thanks for the video and details about your setup and the issue - this is very helpful! I’ve passed this onto our engineering team to see if they can replicate this.
