Suggestions
Hi there, Can I suggest:
  • Playhead jump to first beat by default (instead of song start which is often silence)
  • Bpm and key displayed in Queue without being analysed. Not sure why these things can be displayed in playlists but don’t come over when dropped into the cue.
Long time user, thanks for the great software!
Hi Craig,
Thank you for your feedback.
  1. You can set a cue point and enable “Jump To Cue Point” in the General settings in order to do so
  2. Are you using mainly using Spotify as library source?
