The combination of Denon SC6000M + X1850 and Virtual DJ was just excellent.
As if It is like a dedicated device for Virtual DJ.
I especially liked the ability to control EQ and Real-Time Stems separately with the EQ knobs on X1850 without set to MIDI mapping.
The waveform of the SC6000M has changed accordingly, making it easier to understand visually.
I like djay pro ai because it is easy to use.
So I would like djay pro ai to see full support for Denon SC6000M and X1850 like Virtual DJ.
Hi @Akifumi_Konishi,
Thank you for your post!
While I can’t share our future plans, I can share that our team is actively working to provide official support for all devices on the market!
I will happily put this on our developers radar and we would like to apologize for the inconvenience.
Be assured that I will keep you updated with any news as it comes in, and I hope I can be the bearer of good news sooner rather than later!
Thank you.
I am looking forward to good news.
Hello just a question, Is denon x1850 supported now and to what extent?
Did you get an answer on this?
Hi @Dimitris_Sante, the Denon DJ X1850 Prime is on the list of officially supported hardware for macOS, iOS and Windows. I don’t personally have access to this hardware to confirm, but there are no footnotes on the hardware support page.
I did try to connect the sc6000m with no success, the x1850 connected easily as the lc6000 but if i try to connect them all (2x sc6000m, 2x lc6000 and the x1850) the program recognise only the x1850.
@Dimitris_Sante the SC6000M is not supported. Only the SC6000 is.
