I use the Reloop Mixon 4 and one of its biggest limitations is the ability to have an external source for decks 3 and 4 as there are no aux inputs on the controller. However, my USB audio capture device plugged into the MacBook gives me two aux inputs digitally.
Is it possible to add a feature to digital mix other audio sources on 3 & 4 so that we can blend in something like Novation or an analogue turntable into the mix whithout having to use a hardware mixer in tandem with the Reloop deck? That would be a killer option in my opinion.
I have a real mixer (two in fact), but having the capability to bring in additional sources through the app would be a nice thing to have. If you have nothing useful to add beyond pointless sarcastic comments then please don’t bother to post.
Thanks, I only use digital signals (converted from analogue via external device), I just wondered if those digital signals could be incorporated into the mix within the app and fed out via the digital audio on the Mixon 4 controller.
Hi Jeff,
mixing in analog signals is not possible.
Digital signals can be added to your setup via USB directly to your Mac
You want Algoriddim to write thousands and thousands of lines of code to implement and analogue pass-through feature because you’re too cheap to buy a real mixer?!?
