Support for New Hercules Inpulse 200 “MK3”
Hey,
I’m looking for a MIDI Mapping for IPad / IOS
Hercules Controller (Inpulse 200 MK3) supports the new Mashups-buttons and features.
Hi @DJ-Shameless, welcome to the Community! This new controller is not yet supported in djay. However, I have changed your topic from a question to a suggestion so you and other users can upvote it and we can gauge user demand for this new version of the Inpulse 200. Thanks!
Hi
Thank you very much for your email - great!
Not only a great Software - moreover a SUPER Support!
Greetings DJ Shameless
You’re welcome @DJ-Shameless. Thanks for the positive feedback.
If everything is mapped exactly the same as the mk2 it would be extremely easy to remap those buttons manually
The Mk2 map seems to work well, you just need to change the “DJControl Inpulse 200 Mk2” to “[…] Mk3” towards the end of the xml file. Only tested it for a few minutes and I am a novice, so feedback is welcome.
Here is the Mk2 MIDI mapping file: DJ TechTools - Hercules DJControl Inpulse 200 Mk2 MIDI Map
Hi @Ede_Rancz, welcome to the Community! Thanks for sharing.
That makes sense since the main difference is the neural mix, instrumental/vocal buttons
Hello everyone, support for this hardware has been added in the recently released djay 5.6.5.
@slak_jaw I’m guessing this is not for the “free version” I just purchased my first controller, after using the free version of your software on my laptop for a few weeks.
I picked up the inpulse 200 mk2 based on your comment saying it was now supported. long story short, it tells me to buy a yearly subscription to utilize this controller, which I planned on doing anywa, But I wanted to at least be able to test things out and make sure it was for me before I dropped the 50 bucks.
Hi @Flman, welcome to the Community! Please refer to the Help Center topic below for a detailed comparison of the free vs Pro subscription. There is a small number of controllers that unlock some Pro features, but the Hercules Inpulse 200 mk2 is not one of them. Also, we offer a 7-day free trial of Pro and monthly subscriptions in addition to a yearly one.
