Support for Reloop RP 8000 Mk2 + Reloop RMX 95
Hello, I consider buying Reloop RMX 95 + Two Reloops RP 8000Mk2.
I was wondering, since Reloop RMX 95 is listed as supported hardware, are Reloop RP 8000 MK2 turntables also supported by Djay Pro? I am specifically interested in (i) LCD displays being synchronized with Djay Pro and (ii) being able to select tracks using the rotary buttons on the turntables.
I think the answer would be valuable for all those who are thinking about the above (at least for me) logical combo.
Regards,
Adam
Hi @Dj_Black_Tea, welcome to the Community! Good catch! Looks like we missed adding this to our hardware support page. Yes, the Reloop RP 8000 and 8000MK2 are fully supported by djay and the LCD displays and rotary buttons work. I hope that helps!
Thank you, yes, it helps. And…Reloop RMX 90 is supported as well?:slight_smile: It was released at the same time as RP 8000 MK2s, just out of curiosity.
You’re welcome @Dj_Black_Tea. The RMX-90 is not supported, but the RMX-95 is.
OK, thank you, understand.
You’re welcome @Dj_Black_Tea. Happy to help!
