Surest way to backup BPM analysis data
Can somebody help me find the most reliable way to ensure bpm data is saved to a file no matter what device I use with DJAY Pro? I keep having to halve songs manually as I do a lot of hip hop mixing. I can’t figure out what I’m doing wrong.
Thanks in advance for any advice.
Hi @DJ_A_Diffrance, on macOS, track analysis data is stored here:
~/Library/Group Containers/VJXTL73S8G.com.algoriddim.userdata/Library/Application Support/Algoriddim/
OK thanks.
Is there a similar location on iOS as well?
Hi @DJ_A_Diffrance, the track analysis data is not publicly accessible on iOS, so you can not manually back it up. However, please note that any beat grid edits (i.e. the metadata containing things like half/double, grid markers, etc.) are stored in djay Media Library database file. So in theory, as long as you have that you should be able to recreate the exact same analysis data when re-analyzing songs on iOS. I hope that helps!
