Hi is that possible to make a shift button, to change 1-4 and 5-8 hot cues on My Xone K2 controller?
Is that any way to make a shift button that doesn’t need to hold?
Thank you!
Thank you!
Hey @melodisco ,
Thank you for your question on the Xone K2 mapping options and djay!
Currently, only the Xone:96 and the Xone:PX5 are natively supported on djay Pro AI (Mac and iOS).
With that said, if you’re using the controller with djay Pro AI, you can try mapping it and the shift button yourself, following the steps linked below:
Hope you will find this information useful. Cheers!
