Sync cue points and BPM analysis across multiple Windows devices
Is there a way to sync these across Windows devices? I’m mainly using Tidal for the source music at the minute but will rip my records and CDs at some point.
Thanks,
At least it’s documented where files are stored.
So be sure to do backups based on this
Automating things in Windows is a little bit tricky. By default there isn’t same kind of sync as iCloud.
You could use onedrive, google drive for example.
But I’m “old fashioned” and don’t really trust these cloud backup system.
Buy external hard drive and copy correct directories using that between devices.
In that way you have at least 1 additional back copy of your music lib than your computers.
