Sync function changed?
Your question:
Did you change the synch function in the latest update?
Hi @Buddha_Stretch, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
The sync function has not changed in the last update. Can you please explain what you’re experiencing in more detail?
Sorry for the late reply, been traveling. The synch button currently stays set when pressed, but reverts back to the original bpm, when unsynched. This wasn’t the previous setting. My question is when was this changed
Hi @Buddha_Stretch. No problem. Can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here?
Also, as requested above, please provide details about your setup.
You can close this…saw the change via the latest upgrade thanks
