- Device model: Macbook M1 Pro 2021
- Version of operating system: Mac OS 15.4
- Version of djay: 5.3
- Hardware/controllers used: Technics MK5 with djay DVS Vinyl and Phase
Title: Sync Issue Between Decks When Using Internal Mode on One Side //
Deck B (Internal Mode) does not follow the pitch change when Deck A is WIR or REL
Hi everyone,
I’ve recently noticed something in DJay Pro 5 and wanted to check if this is expected behavior or if there’s a workaround.
Here’s the situation:
I have Deck A (left) connected to a turntable or Phase (in DVS mode) (I only have 1 Turntable), and Deck B (right) is set to Internal Mode. Sync is enabled on both decks.
Now, if I load a 120 BPM track on Deck A and a 128 BPM track on Deck B, Sync adjusts both to, say, 122 BPM — so far, so good.
However, when I start the mix and try to adjust the pitch on Deck A (since I only have one turntable connected), the BPM of Deck A changes as expected, but Deck B (Internal Mode) does not follow the pitch change — it stays locked at the previous BPM. This breaks the synchronization during the transition.
I understand that when Sync is enabled, adjusting the pitch on the currently playing deck usually affects both decks and adjusting the pitch on the other deck will break the sync.
In my case, however, the crossfader is centered and both volume faders are up, meaning both tracks are actively playing — yet only the DVS deck responds to pitch changes, while the deck in Internal Mode does not follow.
Interestingly, if both decks are in DVS or WIR mode (turntable or Phase), everything works as expected — (as long as I’m adjusting the pitch on the currently playing deck) pulls the other along due to Sync.
Crossfader is in the center the whole time, so both decks are active in the mix.
Is this a limitation when combining DVS with Internal Mode? Or am I missing a setting that would make the Internal deck follow the pitch changes from the DVS deck?
Thanks in advance for your help!
Best,
Essa
