Hi when I load up a song even without sync on the loaded song syncs to the currently playing songs bpm. Also if I stop playing the current song and load a new song, the previously playing song syncs to the newly loaded songs bpm.
Note both the Resume Sync After Pause, Scratch or Cue Jump and the Maintain Sync on Song Load settings are OFF.
With the Crossfader FX turned OFF, during an Automix Transition, the volume Jumps Up then Crossfader FX activates then the volume drops back to Normal Volume after transition is Complete. There’s literally No Way to keep CFX from activating as there’s not a “None” Option in the CFX Transition List. I’ve tried EVERY Setting and Disabled All FX and it still comes on without fail when using AutoMix. When are you all going to fix this back to the way it used to be. No Volume Spiking or Forced FX Transitions. There’s WAY Too Many DJs dealing with this at there Gigs without a Solution. There needs to be a “No Transitions” Option that WILL NOT Turn On by Itself. I’ve uninstalled and reinstalled and get the Same Issue.
