Sync mode 1 beat error
iPad 10
macbook air 2020
djay 5.3.2
As of this new update 5.3.2,
I cannot synchronize to 1 BEAT as in previous versions.
Let me explain: in this image I have marked with a HOT CUE every 4 MEASURES or 16 BEATS, djay correctly identified the TIME. When mixing with another track the SYNC function will do its job.
Okay, now. The music will not always be square (as I call it) it will not always make a change of PHRASES at 16 BEATS or 8 BEATS, sometimes for dynamics in a drum roll it will enter half MEASURE before starting again the PHRASE of 16 BEATS.
Then Djay will not interpret these small changes and will think that all the music keeps the constant rhythm of 16 BEATS.
This is where the “BEAT SYNC INTERVAL” option came in, to be able to mix correctly in TIME, you could sync to 1 BEAT and those who wanted to could sync to 4 BEATS.
As in the image, the same song, minutes later, when trying to mix here the correct thing to do is to start the first BEAT of the other song, where the green arrow indicates. And not where Djay marked the Bar 85, because if I do that, it will produce the horse gallop effect, that two tracks are synchronized but the Kick of them sounds one after the other, how a delay
Now 1 BEAT does not work and is automatically magnetized to the bar marked by djay
Please fix that bug and really, thank you for being a great software that listens to its users.
A post was merged into an existing topic: CFX syncs to 1 Beat instead of 4 Beats
Merged with existing topic: CFX syncs to 1 Beat instead of 4 Beats
