For some reason the sync or anylising of tracks doesn’t seem as good as djay2. Just doesn’t lock as tight. Any reason why this is?
Occasionally as well for some unknown reason but some tracks won’t sync at all the sync light doesn’t light up. This only happens on a couple of my tracks.
I have exactly the same problem with the last update of DJay Pro (version 1.3.1). I came back to the previous version (1.2.1) as 1.3.1 update is not stable neither reliable. It needs to be fixed again. Thanks.
Hi guys,
if you are referring to the Grid slightly appearing to move while being in sync mode, this is due a re-analysation/ re-syncing on the flight.
This new implementation is being more precise.
Regarding songs which are not syncing, could you send the track or the Spotify song information?
Thank you in advance.
