Just bought a new Ipad Pro 13 16 ram and installed Djay Pro but the sync is not working. I can´t automatically beat match songs. In my older Ipad it works seemingly
Can you explain exactly what is going on?
Also can you check your Settings/General/Sync Mode and see what the settings there are set to
I load a track and start mixing and the new song stays the same. No change of speed and no syncing. The settings are the same a my old Ipad (I kept it)
Have you analyzed your tracks?
did you activate the sync button?
Hi @manecascais, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Also, can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hello! It’s been more than 7 days since my last reply. I’m going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
