Sync Rekordbox cloud collection in djay on Android
YOUR QUESTION:
  1. I want to use the Android version but how to get my cloud collection from rekordbox android app to dji Android?
Hi @DjSasha_DelhiDevils, currently there is no method to import your Android Rekordbox Cloud Collection into djay on Android.
any way to sync my windows laptop dj pro collection with my andriod dj pro ?
Unfortunately not at the moment.
Plz add cloud library sync option…just like rekordbox…ur app is much better but a pro dj needs to sync collection across devices.
Hi @DjSasha_DelhiDevils, I’ve changed your topic from a Question to a Suggestion and will pass this onto our dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Can my one Library playlist be used on Android dj pro via a usb?
OneLibrary is not yet supported on Android @DjSasha_DelhiDevils
Once i copy my one drive playlist to my iphone, how to delete the copied file in phone so that the next time I load the update list I don’t create multiple copies of same tracks
Hi @DjSasha_DelhiDevils, when you select the Action>Add to My Collection for the OneLibrary playlist, you will be offered some options (see below):
This method should prevent any duplication if you maintain the playlist names and song names.
