Hi, I reluctantly updated to ios7 on Sunday & i’ve updated all my apps to suit, i’ve noticed a slight change in the sync feature, I feel it dosen’t keep the beats in sync as good as before, its almost a couple micro settings in front. Anyone else finding this or is it just me?
Hi Nick,
The sync feature should work the same on every supported iOS. Which djay version are you using? And also, are you syncing manually or using “Perfect Sync”?
Try pressing the SYNC button twice (so it lights up in blue).
Djay Version 2.2.1, iOS 7.0.4, Its only very slight, I sync using the sync button, then drop the record using the same method to enable a nice crisp drop. Whats perfect sync?
